3000GT 800HP+ from Ukraine (ASO-motorsport)
Re: 3000GT 800HP+ from Ukraine (ASO-motorsport)
But you can buy an extra boost solenoid for the AEM ECU and have the ECU do boost control. With AEM ECU you do not need an extra boost controller.
I agree about the AVC-R, I also have one.
- Andre_3000gt
How I can download photos 800x600 pixels here?
- Andre_3000gt
Wow your exhaust headers are very impressive!
The whole exhaust is nice. No stupid things like a Cat, just a straight pipe. Why dont we do it like this? I cant remember...
- Andre_3000gt
we make different turbokits. Maybe someone from Germany want to buy one of our turbokit?
For 600? 700? 800 and 1000 Horsepower...
Do you know the word "TüV" ?
Andre_3000gt hat geschrieben:we make different turbokits. Maybe someone from Germany want to buy one of our turbokit?
Yeah! I like your Single Turbokit, but no chance with the German TÜV.. we need a more "sleeper"-look, or just smaller Turbokits.. (stock looking Intake Manifold, smaller Intercooler) to get a chance in Germany.unQz hat geschrieben:Do you know the word "TüV" ?
Greets
- Andre_3000gt
stock view:Detonator hat geschrieben:Andre_3000gt hat geschrieben:we make different turbokits. Maybe someone from Germany want to buy one of our turbokit?
For 600? 700? 800 and 1000 Horsepower...Yeah! I like your Single Turbokit, but no chance with the German TÜV.. we need a more "sleeper"-look, or just smaller Turbokits.. (stock looking Intake Manifold, smaller Intercooler) to get a chance in Germany.unQz hat geschrieben:Do you know the word "TüV" ?
Greets
http://www.gtooc.org/forum/viewtopic.php?f=50&t=1032
http://www.aso-motorsport.com/cars/3000 ... ttt231.jpg
- Andre_3000gt
Hi all, I'm from Ukraine, I was create Mitsubishi 3000GT 800HP+
I'm owner of tuning company ASO-motorsport.
We build the drag, drift, ciquit, rally cars projects.
You can see more of our works in our site or in Facebook. Look in my signature.
Mitsubishi 3000GT VR4 1993 JMBMNZ16APY000490
I have this car 7 years.
Specs:
-Turbo – Garrett GT42RS/4094 twinscroll after tuning, another compressor wheel and rotor
-2 Wastegates — TIAL -44 mm, springs 0,9 Bar,
-Blowoff of Valve TIAL Blue 50 mm,
-Exhaust manifolds — custom made, SS + Wrap DEI,
-Exhaust system 90mm Custom made, 2 mufflers HKS HiPower,
-Intake Manifold custom made,
-Filtre K&N,
-Throttle body 76mm (3") — OMNITEC,
-Fuel Rails — GT PRO,
-Fuel magistrals — AEROMOTIVE + 10micron filter + fuel presure regulator AEROMOTIVE
-2 fuel pumps WALBRO 255 lрh — exterior,
-Fuel tank RCI (54 litres),
-Fuel Injectors 880cc PRECISION,
-Front intecooler GODSPEED -700х350х100 + NOS cooler system,
-Oil Catch Tank GREDDY,
-Oil radiator KOYO,
-Radiator KOYORAD,
MOTEUR:
-Forget Pistons PAUTER,
-Forget Rods СP PISONS 93.0mm,
-Bearings CLEVITE,
-Forged Crankshaft BC,
-Head bolts — ARP,
-Porting Heads Stage 4,
-Bronze Valve guides Supertech,
-Camshafts BC 272/272,
-Head gasket OEM MITSUBISHI, (Pourquoi pas Cometic? Parce que je fais chier sur Cometic, sur 6g72 ils non ok)
-Valves INCONEL,
-Valves springs 3SX,
-Cam Gears FIDANZA blue,
-Kevlar Cam Belt POWER ENTERPRISE,
-Spark Plugs DENSO IK27,
-Spark Plugs wires ACCEL
-Oil pump RALLIART,
-Water Pump OEM,
-Thermostat 76 degree RALLIART,
-Engine mounts Custom made,
-Triple Carbon Clutch ATS ACROSS PITROADM,
-Transmission output shaft and Transer Case input internal - KORMEX TRANS,
-Transmission 6 sp. GETRAG tuned — Supercarengineering,
-Front LSD - Supercarengineering,
-Carbon Driveshaft 1 piece - PITROADM,
-Engine mamagement ECU AEM EMS,
-Ignition module MSD DIS4,
-Gauges DEFI BF white — 6 gauges,
-Boostcontroller APEX'i AVC-R (Black),
-MAP sensor AEM 3,5 Bar,
-AEM UEGO,
-Methanol injection system — SNOW performance St2,
-Short shifter PITROADM,
-Steering wheel MOMO with quick release hub NGR,
-Brake system ROTORA, front 6 pistons 380mm, rear 4 pistons 380mm, + armored bracke lines, ABS deleted.
-Rims RAYS NISMO LM4 18x9.5 (white edition) 6.8 kg.
-Tires FALKEN 452F 265/35/18,
-Carbon hood SEIBON,
-Carbon thunk VIS,
-Bodykit - PITROADM Pit Fighter,
-Wide body kit - CIANCI,
-Carbon mirrors - TCS,
-All Oils and Antifreez - MOTUL,
Specs:
-Filtre K&N,
-Oil radiator KOYO,
-Radiator KOYORAD,
MOTEUR:
-Bearings CLEVITE,
-Head bolts — ARP,
-Valves INCONEL,
-Oil pump RALLIART,
-Water Pump OEM,
-AEM UEGO,
-Carbon thunk VIS,
- Andre_3000gt
Japan Flywheel
New forged Crankshaft
- Andre_3000gt
second head
- Andre_3000gt
Lift exhaust valves
Lift intake valves
two heads together
