3000GT 800HP+ from Ukraine (ASO-motorsport)
- Andre_3000gt
Hi all! I'm happy to visit Your forum.
I'm from Ukraine. I have Mitsubishi 3000GT VR4 800HP+
I am owner of ukrainian tuning company ASO-motorsport:
http://www.aso-motorsport.com
ASO-motorsport in Facebook:
http://www.facebook.com/pages/ASO-motor ... 2002562790
My car:
http://www.facebook.com/album.php?aid=2 ... 2002562790
Details of my car:
Mitsubishi 3000GT VR4 1993 JMBMNZ16APY000490
I have this car 7 years.
Specs:
-Turbo – Garrett GT42RS/4094 twinscroll after tuning,
-2 Wastegates — TIAL -44 mm, springs 0,9 Bar,
-Blowoff of Valve TIAL Blue 50 mm,
-Exhaust manifolds — custom made, SS + Wrap DEI,
-Exhaust system 90mm Custom made, 2 mufflers HKS HiPower,
-Intake Manifold custom made,
-Filtre K&N,
-Throttle body 76mm (3") — OMNITEC,
-Fuel Rails — GT PRO,
-Fuel magistrals — AEROMOTIVE + 10micron filter + fuel presure regulator AEROMOTIVE
-2 fuel pumps WALBRO 255 lрh — exterior,
-Fuel tank RCI (54 litres),
-Fuel Injectors 880cc PRECISION,
-Front intecooler GODSPEED -700х350х100 + NOS cooler system,
-Oil Catch Tank GREDDY,
-Oil radiator KOYO,
-Radiator KOYORAD,
MOTEUR:
-Forget Pistons PAUTER,
-Forget Rods СP PISONS 93.0mm,
-Bearings CLEVITE,
-Forged Crankshaft BC,
-Head bolts — ARP,
-Porting Heads Stage 4,
-Bronze Valve guides Supertech,
-Camshafts BC 272/272,
-Head gasket OEM MITSUBISHI, (Pourquoi pas Cometic? Parce que je fais chier sur Cometic, sur 6g72 ils non ok)
-Valves INCONEL,
-Valves springs 3SX,
-Cam Gears FIDANZA blue,
-Kevlar Cam Belt POWER ENTERPRISE,
-Spark Plugs DENSO IK27,
-Spark Plugs wires ACCEL
-Oil pump RALLIART,
-Water Pump OEM,
-Thermostat 76 degree RALLIART,
-Engine mounts Custom made,
-Triple Carbon Clutch ATS ACROSS PITROADM,
-Transmission output shaft and Transer Case input internal - KORMEX TRANS,
-Transmission 6 sp. GETRAG tuned — Supercarengineering,
-Front LSD - Supercarengineering,
-Carbon Driveshaft 1 piece - PITROADM,
-Engine mamagement ECU AEM EMS,
-Ignition module MSD DIS4,
-Gauges DEFI BF white — 6 gauges,
-Boostcontroller APEX'i AVC-R (Black),
-MAP sensor AEM 3,5 Bar,
-AEM UEGO,
-Methanol injection system — SNOW performance St2,
-Short shifter PITROADM,
-Steering wheel MOMO with quick release hub NGR,
-Brake system ROTORA, front 6 pistons 380mm, rear 4 pistons 380mm, + armored bracke lines, ABS deleted.
-Rims RAYS NISMO LM4 18x9.5 (white edition) 6.8 kg.
-Tires FALKEN 452F 265/35/18,
-Carbon hood SEIBON,
-Carbon thunk VIS,
-Bodykit - PITROADM Pit Fighter,
-Wide body kit - CIANCI,
-Carbon mirrors - TCS,
-All Oils and Antifreez - MOTUL,
But i can't post here the pictures, because Your forum wrote me:
"It was not possible to determine the dimensions of the image"
I have the pictures only in 800x600 pixels...
My car:
Details of my car:
Specs:
-Filtre K&N,
-Oil radiator KOYO,
-Radiator KOYORAD,
MOTEUR:
-Bearings CLEVITE,
-Head bolts — ARP,
-Valves INCONEL,
-Oil pump RALLIART,
-Water Pump OEM,
-AEM UEGO,
-Carbon thunk VIS,
Re: 3000GT 800HP+ from Ukraine (ASO-motorsport)
Welcome to the german GT-Forum. Nice car do you have ... and a lot of modification. =D>
Drive save.
Greetings from me
Drive save.
Greetings from me
Wow, that would bring you to the first place in our performance list - if we had one
Welcome to the forum, nice to have you here!
Regards from Berlin,
- Andre_3000gt
Thanks guys.
Tell me please how I can insert here my pictures ???
and videos???
and videos???
This page doesn`t have a own Database. For Videos or Pictues you must use extern Database for example Youtube (Videos) or imageshack (Pictures).
Videos can only posted by URL-link to the extern Database. For Pictures use the bbcode [img]-Tags. Unfortunately there maybe actually a general problem at our Forum. Some Member have the same problem.
So the only solution at the moment is to use the URL-link.
god damit!! You need a fcking Wing
Youre "mashine" is great. Take care about it.
- Andre_3000gt
I have external server. But Your server can't open 800x600 pics. If you can, give me please the acces to post here pictures () 800x600 pixels... I thing It's will be interess!
Welcome to the forum.
As I was scrolling through the pics on Facebook and your add-list & I noticed that your are missing some Suspension upgrades (car looks stock on this part).
Pictures might be misleading in this case. But can you confirm on it? Otherwise with this amount of HP you might wanna think about better suspension.
Anyway, I was just curious. Nice to have you with us.
Greetz
Greetz
- Andre_3000gt
I was buy KW Variant3 suspenssion kit,
Hi Dude
A fucking nice Car
A fucking nice Car
Very good choice.Andre_3000gt hat geschrieben:I was buy KW Variant3 suspenssion kit,
Why did you do the boost control with Apexi AVC-R and not with the AEM?
Hi this is mike, we already met in facebook...i like the fact that u sign up in our forum.
i wish u the best with ur car..i will also buy the kw variant3 suspension kit, its one of the best for our cars...
best regards,
Mike (Maik)
best regards,
Mike (Maik)
- Andre_3000gt
Because I have AEM EMS Ecu computer, but external boostcontroller (with solenoid) I have more 3 year APEX'i AVCR - I think this device is better than HKS EVC, BLITZ, Greddy. What about AEM - AEM true boost boost controller - it's bullshit. No advise options.Tiberius hat geschrieben:Very good choice.Andre_3000gt hat geschrieben:I was buy KW Variant3 suspenssion kit,
AVCR show me allways Speed, Boost, RPM, TPS, and the peaks of this parameters.
