Ein "Aufsatz" für das H-Getriebe, das dann sequenziell zu schalten geht.
http://supercar-engineering.com/sc2/pro ... cts_id=291
Was haltet ihr davon?. Auf Wunsch auch für das 5 Gang Getriebe. Der Ami schreibt natürlich das es super
funktioniert, in den Ami Foren hab ich aber noch nicht wirklich viel darüber gefunden....
This is a mechanical shifter with an electromagnetic assist that works with the standard 3000GT/Stealth 6-speed transmission and converts the standard H-pattern into sequential. It makes shifting much quicker and saves engines from overrev failures by eliminating shift errors caused by accidentally getting into a wrong gate of the H-pattern shifter. Works great with standard 6-speed transmissions and with dogbox transmissions.
The whole shifter can be hidden into the center console for an OEM-like finish.
The gear indicator display can be ordered large square (as shown) or small 40mm round.
